RCU Forums - View Single Post - problem with 9C super glider programming
Old 06-13-2006 | 11:24 AM
marcellus
Default RE: problem with 9C super glider programming
You can use negative differential by mixing ail1 with ail1 and ail1 with aux1. This would be actuated when the throttle reached say 50% of movement. The down going one will move more at this point and keep lateral control when you've limited the amount of up movement in the aileron. Glad to give you the exact settings if you are interested.
