RE: Cover Stabilizer now or later???
Hi Brad,
Greetings to the Indian Ocean side of Oz. I bet you're glad that Cyclone season is over?
What you propose will work. My preference is to glue the stab and fin to the fuse first and then cover with the cloth and epoxy. Once set I then mix some resin and micro baloons to make a fillet at the join. This alows you to use less resin (weight) and gives you time to concentrate on shaping the fillet.
Cheers,
Colin
