RE: Do I need a spinner ?
There is one definte advantage to using a spinner... when the prop is kicked loose because your prop nut wasn't quite tight enough, the spinner will make it easier to find the propwasher and prop nut... they'll be inside the spinner.... instead of lying around in the grass.... somwhere.
