RE: Genesis Problem :(
The clutchbell itself? that will not spin untill rpm's come up. If you give it throttle does the clutchbell still not spin? I would pull the cluthbell and inspect the clutch shoes and the springs... Are you positive the forward\reverse lever is fully engaged?
