RCU Forums - View Single Post - TS2 POST IT HERE...
Old 06-15-2006 | 07:57 PM
wave waker
Default RE: TS2 POST IT HERE...
ORIGINAL: dougaldy
Thanks Wave Waker, now my next question is, how come the distance between the glowplug and pipe matters? Is this something you found out through trial and error?
i learnt it from other boaters too, this is the method of setting up tuned pipe, start by measuring from glow plug to the widest part of the pipe maybe 13-14 inches to be safe then run the boat if the engine keep boggin' down or won't rev high cut the coupling by 1/2 until engine giving good rpm,,mostly i know 3.5 engine needs around 10-11 inches, i do no with 7.5 but mine i found it somewhere 13-14 inches.
thanks zapster...
