Bignasdy,
I would have a frigin 1/2" slot long before the wing fit in there. I have never seen a ARF with this bad of a wing joint.
The holes and dowels appear to be in the correct location. If I slotted the hole to fit the dowel, the belly would be 1/4-3/8 beneeth the bottom of the fuse (like I said earlier, the profile of the saddle is incorrect).
How do you really know which is correct (saddle or dowel locations),since the incidence is not published.[sm=confused.gif] Hell, the spec's for the wing area and engine size are not even consistant from the manual to the box label.
