ORIGINAL: uakeaflys
Aloha everyone!
I'm finishing my 1st trainer. Just wanted to make sure I'm able to use any open channel not being used on my receiver for my switch? I have a Futaba 7cap tx. Can anyone help?
Yes, you can use, any open slot,or use a "Y" harness ,on a used/plugged in channel.If you have a slot marked as "BATT", the switch ,should be installed, in-line with the battery, to that slot.You can`t really "Goof up"...Hope things go well for you....
