Post-xmas UCD3C assembly tips and customizations.
Tons of people just got new UCD ARF's for xmas and trying to find info in the old thread over in 3D flying is nearly impossible.
Before we all start assembling our new plane, lets list the most common concerns or issues that should be deealt with while putting this plane together.
Some suggestions I've heard are:
1) Reinforcing the landing gear block.
2) adding a pull-pull system for rudder.
3) Adding some "right thrust" to the engine mount by inserting 2-3 washers behind mount. Can someone help with which side of mount? I believe if you are looking at the nose of the plane head-on the washers should go on the right side of the mount.
4) Some people are using aftermarket tailwheel assemblies. The one that comes with the kit is a little lackluster.
5) People with "pumped" engines (YS, OS pumpers, perrys, and clines) are mounting the tank at the CG of the plane.
6) The less weight the better. Don't bother with Pilot figures or onboard glow starters. However, a remote glowplug connector is highly recommended.
