AW 29% Edge, Downthrust??
For all of you that have built and love this plane, have you had to add any down thrust in the engine mount? Right thrust is specified in the instructions. What is your experience. using a BME 50 on the plane.
Any other advice appreciated. Did you fill the large hole that AW use to cut the wing tube out with foam?? looks like a good place for a finger to go through the thin balsa.
mark
