RCU Forums - View Single Post - Plans or kit :Tigertail IV??
Old 06-18-2006 | 08:16 AM
  #127
ramcfarland's Avatar
ramcfarland
My Feedback: (44)
Default RE: Plans or kit :Tigertail IV??
First I glassed the wing trailing edges where they accommodate the ailerons leading edge. Next the left and right aileron servos are fitted fitted ,with push rods being set up (will probably use Titanium links,)to connect the servo to the Ail control horn;since the ailerons are of foam with balsa sheet skin I installed 1/2'dowels as hard points and drilled them for the control arm first before gluing in place.
Finally some sanding to the bottom wing and its time to glass the entire wing.
