RE: Futaba 9Z expert Question?
I don't have the radio anymore, but, I checked with the manual and it states that only the throttle goes to failsafe on low voltage. For the normal loss of radio type thing you get to choose hold or FS for each channel. You cannot set the FS voltage. The throttle can be brought back from the battery FS setting on command (assuming your battery still has enough power).
The 14mz lets you adjust each channel for each of the two failsafe conditions.
Regards, Guy
