RE: Help on using ice charger
The pack equalisation can be checked by monitoring each individual cell, or a known matched pack that has been equalised will be quite equal. If it's a stick pack with loose cells then just use 8-10 volts.
The manufacturuer should list the max discharge current. Or have to be tested.
