RCU Forums - View Single Post - What is the correct way to run pull pull cables?
Old 06-18-2006 | 08:31 PM
Woodpile
Default RE: What is the correct way to run pull pull cables?
Be careful about using tubing to guide the cables around fuse members. Eventually, the cables will wear through the wood and cuase slack which will then result in a very exciting flight.
You might want to think about crossing the cables so they take up as little area as possible...
Ed
