What is the correct way to run pull pull cables?
WI
I am putting a pull pull system on my plane. When I run the wires through the fussalage I am haveing a problem with the wires going aroung the fusalage spars. I have no way of getting in there to cut holes in the spars to plumb the wire through. What is the correct way of doing this?
Thanks everyone
Thanks everyone
I'm doing a pull pull on my EAA bipe. I'm trying out Sullivan kevlar-aramid cables They have guide tubes so you don't have to worry about rubbing
Danny
Danny
WI
Thanks for the reply Danny. I think I'm just going to run the wires through some 2/56 tubing. Just enough to get around the ribs. My du bro kit did'nt come with any tubing. I can't think of a better way of doing it. Thank you !!
NJ
Be careful about using tubing to guide the cables around fuse members. Eventually, the cables will wear through the wood and cuase slack which will then result in a very exciting flight.
You might want to think about crossing the cables so they take up as little area as possible...
Ed
Ed
WI
Thanks Paul, I never herd of crossing the cables. That might make up for the difference. I will give it a try.
My Feedback: (35)
Chadderbox, the following link has some drawings of three different pull/pull cable layouts.
http://www.swbmfg.com/rudex.html
I have used nothing but pull-pull on both elevator and rudder on all my 1/4 scale. I use nylon coated fishing leader material routed thru nylon tubes. Some are over 12 years old with heavy use and none have ever worn thru the tubes. I even use the tubing to route the cables in something other than a direct line with no problems. A good source of tubing is Hobby Lobby, you can get 25 ft. rolls rather inexpensively. Chadderbox, I'm curiouse, I've never heard of spars in a fuselage, do you mean stringers or do you mean the bulkheads?
WI
They must be called bulk heads. They run every six inches or so through the entire fuselauge. Thanks for your help!! Chad
