RCU Forums - View Single Post - One servo, Two elevator halves?
Old 06-19-2006 | 07:14 AM
exeter_acres's Avatar
exeter_acres
Default RE: One servo, Two elevator halves?
done all the time in many planes... (mostly smaller) you can put the servo in the fuse and then run 2 seperate control rods back to each half...
or some planes have a torque rod that connect the two halves...
Which plane?
might be able to give better directions if the plane is known
