RCU Forums - View Single Post - TMaxx shafts on FunFactor - complete guide!!
Old 06-19-2006 | 01:44 PM
cenracer1
Default RE: TMaxx shafts on FunFactor - complete guide!!
PJ... I was looking at your pics on this link and I see you cut your female shaft very short.. the male end is quite long.. mine, the female end hits the spring cup on the shock because the female tube is thicker.. If I can't sort it with my hack mods... I will buy some servo mounts off tower hobbies.. they are fairly cheap.... I'm pretty sure I can get it to work without interference buy using longer eyelets on the bottom of the shock... only needs to be about 2mm taller... It just hits on full lock turns...
