RCU Forums - View Single Post - T-rex blade tracking -please help
Old 06-20-2006 | 10:50 AM
WhtBronco's Avatar
WhtBronco
Default RE: T-rex blade tracking -please help
When you adjust the tracking you are changing the pitch of 1 blade. The idea is that 1 blade is lifting more than the other, pitch. So the blade you used to set the tracking with is the blade you set the other to match. The pushrod at the blade grip is for larger adjustments while the pushrod from the swash to the mixing arm ios for smaller adjustments.
