Go Back  RCU Forums > RC Helicopters > Electric RC Helis > T-Rex heli
 T-rex blade tracking -please help >
T-Rex heli For all you T-Rex lovers out there, this where you can post!
Old 06-20-2006 | 07:52 AM
Default T-rex blade tracking -please help
Hi everyone,
I'm new to the T-rex (and helis) and I'm trying to set the blade tracking. I'm having trouble doing so. First thing I did was balance the blades iusing a balancer and then I mounted them. According to the instruction manual, it says to adjust either linkage rod A or linkage rod D until you get level tracking. It seems like when adjusting these rods (especially rod A), it's only changing the pitch of the blade. Am I missing something here? Any help would be greatly appreciated. This is the only thing keeping me from trying this thing out. Thanks in advance.
Rob
Old 06-20-2006 | 10:50 AM
WhtBronco's Avatar
Default RE: T-rex blade tracking -please help
When you adjust the tracking you are changing the pitch of 1 blade. The idea is that 1 blade is lifting more than the other, pitch. So the blade you used to set the tracking with is the blade you set the other to match. The pushrod at the blade grip is for larger adjustments while the pushrod from the swash to the mixing arm ios for smaller adjustments.
Old 06-20-2006 | 11:04 AM
Oh, ok...I understand. Thanks.
I will keep fiddling with it until I can get it right.
Old 06-20-2006 | 11:21 AM
You'll also need to physically hover your helicopter to ensure tracking is right. Checking it on the ground rarely works. Tracking on the ground and in the air are almost always different.
Old 06-21-2006 | 11:09 AM
Makes sense...more force on the blades. Thanks for the advice, I'll make sure I do that.
I was able to get it tracking right last night (on the ground). I found that my problem was with swashplate and
flybar not being level to begin with, throwing off everything.
Old 06-21-2006 | 11:14 AM
if you are still having problems bob finless videos work great and help explain everthing alot better then trying to read it out of a book and it will save you alot of time.
Old 06-21-2006 | 01:46 PM
Ok... I may check that out. Thanks for the advice.
Thanks to everyone for their replies.
