RCU Forums - View Single Post - CONTINUATION..H9 HELLCAT FIRST 2 FLIGHTS
Old 06-20-2006 | 03:15 PM
  #43
Pit-Viper 1's Avatar
Pit-Viper 1
My Feedback: (12)
Default RE: CONTINUATION..H9 HELLCAT MINES OK HOWS YERS?
Yeah the G26 is heavier and in my application the extra weight is needed. I was using the RCV.91CD and it flies it nice but it just isn't quite enough to pull it around even for scale flight. If your thiking of the Saito 100 and if the extra cash isn't a problem, you should go with the 1.25. My buddy used the 100 in a the H9 P-51 then he put the 1.25 out of his showtime in it and that thing has gobs more power. Just a thought. It's kinda funny when you put the Saito 1.20 and the 1.25 side by side cause the 1.20 looks huge compared to the 1.25. Here's the 1.00 and 1.25 together, can you tell which is which? He uses an APC 16x8 and the plane is around 8-9lbs. and will almost hover, lol
Shane
ID:	480347   Click image for larger version
