RE: Shoe Goo
I have used GOOP many times.I use it on new bodies i paint.You know those areas that seem to get split first.The corners of fenders and roof and trunk lid.Just spread a little dab in the corner before you ever use the body.If i get a crack after the body has been run,then just clean it good TAPE THE OUTSIDE WITH MASKING TAPE,apply GOOP to the inside and let dry,then remove tape.I have beat up some bodies pretty good and this stuff is really tuff.
