RE: Fut S9252 Servos with Powerbox ?
Thanks for the responses/information guys. Here is some additional information I got ...... which leads me to believe that I will be OK First, I am really not using a 5 cell pack, I am using a Powerbox that regulates the voltage to 5.9 volts (constant). It was explained to me that 4 cell packs, when fully charged, usually deliver almost 6 volts, and, 5 cell packs, when fully charged, deliver almost 7.5 volts. I was told that the reason for the '4.8 Volts Only' note on the box is so that people do not use a 5 cell pack ..... which would deliver (at times) 7.5 volts. Since the standard 4-cell/4.8 volt pack delivers (at times) 6 volts, then my Powerbox (which delivers 5.9 volts) should be fine. This sort of makes sense to me ........ what do you think ? Bob
