RE: Boothbay Oyster boat
LTDoc every little bit of info helps. I made one error on this model, I made it too solid. My main deck is my only deck and is 3/16" ply.The frames glue to the deck sealing in the area between frames. I will either have to use the resin/shot combo and disguise them as deck ornamentation (boxes, tubs) or I will have to make a thin box almost the full width of the hull. I have a rudder servo sitting on one side under the transom hatch so there isn't much room for ballast.
Here is a weird thought that just struck me. Drill a hole in the deck very near the transom on either side of the keel. Then insert a balloon in each hole and add the shot. Once I got the right amount of shot I could add resin into the balloon then seal off the holes. Good idea or bad?
Tug
