RCU Forums - View Single Post - Need help with crosswind landings
Old 06-22-2006 | 09:05 PM
elenasgrumpy
Default RE: Need help with crosswind landings
STOP YELLING!! lol I just kind of bring her in at angle sort of sideways with the nose pointing into the crosswind, then I just kind of kick the tail feather straight at the last minute with the rudder just before I set her down. It is probably not the correct method but I do it all the time & it seems to work well for me. I just kind of feel my wsy thru it. It allows me to fly in winds that ground a lot of the other guys at our field.
I'm sure some of the more experienced fliers can give you better advice as to the proper method, like I said I just kind of found a way to feel my way thru it using almost all rudder & very little aileron if any. Practice & you will get it. That is also something the sim is pretty handy for if you have one. Turn up the wind up good & high with a 45% crosswind & have at it. Good luck.
