RCU Forums - View Single Post - Need help with crosswind landings
Old 06-22-2006 | 09:17 PM
ptmac3's Avatar
ptmac3
Default RE: Need help with crosswind landings
Learn to use the rudder to correct your heading. Try to think of it as if you were actually sitting in the cockpit. If the wind is blowing from the right feed in a little right rudder until you see a heading change. Keep the wings level with the ailerons if necessary. Keep working the throttle.
