RE: Boothbay Oyster boat
Tug,
Good question. Does resin affect rubber baloons? Beats me. Being naturally lazy, I'd find the weight of ballast I needed, then cut hole dump in the hull bottom and add glue/resin. Split it evenly if the keel would be in the way. Or, be a bit more 'picky' when finding the correct ballast weight, for each side. On second thought, I think I'm lazier than that. Try the baloon thingy first.
- 'Doc
And after 'third' thoughts (meaning I reread your post, and since you've got the keel thing covered anyway) I'm starting to think I ain't thinking straight tonight...
