RE: P38 lightening 12 by Raidentech/nitromodels
Glacier, can you tell me if the C.G. point is measured back from the front middle of the wing where the canopy is or is it measured from the outside of either one of the fuselages on the P38?
Do I turn the plane upside down to check CG from the top of the wing. Or right side up to check CG from bottom of wing?
Mine is built and I'm just trying to decide where to put the two batteries. I have prewired them to be in the gas tank compartment behind the firewall. May need to open up more air inlets.
Carl
