RE: Paramount 52/70
Salty--
I built one of these as a raffle plane for a club function. It was generously donated with an OS 70 FS and radio by our local hobby shop. Wait till you try and install engine mounts/engine/cowl. Oh and the pickle fork that runs the elevator. It is supposed to be a 3D plane, but there is not room to mount the elevator and rudder servos and still have enough room for servo arms with enough length for 3D throws. You might consider stacking the servos if you want wild throws. None of the cross brace balsa sticks were cut on an angle, just square ends butt glues into corners--check the airelons. I'm sure it will fly OK but it was the most frustrating ARF assembly I have experienced. If you are looking for a great ARF that is similar to this turkey, check out the Seagull Harrier. It comes in a 40 and 60 size and was an easy build and is a delight to fly.
Good luck and post your impressions of this kit.
Greg
