RCU Forums - View Single Post - DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Old 06-23-2006 | 02:05 PM
  #70
3dsky's Avatar
3dsky
My Feedback: (84)
Default RE: DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
Well guys I just got back from the flying field and the DA ran great out of the box. I used the needle settings the way DA set them for the first flight. It ran a little rich as I would expect. It ran exactly the same in the air as on the ground. I did only one tail slide at idle and no problem going back up on the throttle. Knife edge left or right and in down lines no change in RPM. I had instant response to the throttle stick with even the rich settings. Did an upright somewhat flat spin at idle with no problem. Far as I am concerned the balsa box works great. Only 10 minute flight and how I am going to set the needles and that is the end of that.
Thanks jongurley great tip
Later,I have some flying to do.
