RCU Forums - View Single Post - quick question on glassing.......
Old 06-23-2006 | 05:16 PM
parrthd
Default quick question on glassing.......
I had a wing failure on an avistar select mkII (i was training a friend with my plane) and the wing dihedral block gave way to glue failure (apparently i didn't use enough. I've jointed the wing back together with 30 min epoxy, repaired all the sheeting and glassed the wing joint. I didn't use thin ca (tip thanks to sig manf.) because the glass was 8 inches wide (just to be safe). I used 30 min epoxy thinned with alcohol.
My question is this, is this a common practice that will work for the intended purpose, or should I have ordered and used fiberglass resin (on my next order's wish list) ???
