RE: CONTINUATION..H9 HELLCAT MINES OK HOWS YERS?
The manuel is wrong. It says to use one 1" spacing between the servo arm connectors. It needs to be 3/4". Just measure the distance the wire moves from the bellcrank to the servo arm with the gear fully extended and retracted. It will be 3/4". That is the distance you need between the fastners on the servo arm.
