Whoa, this lil plane rocks ! I put an old reliabe 46fx on it. It still came out nose heavy but I went ahead and took her up without addin tail weight and while it does need to be balanced better she still flies great. Rolls are fast ! I found that if you take the high low approach you can cut throttle, pull it around to final and just add a little throttle before it touches down. It kept falling out af hover but I think once it gets balanced right it should hover pretty good. It definitely needs mucho mixing to get it to knifedge butI decided to keep it simple and not mess with it today.
Must say Im very satisfied with this lil' thang. Im surprised how well the FX pulled it around and even with the needed tailweight it should hover fairly well I think. Weather was perfect today too, 0 wind and 62 deg. I wish every Sunday could be this nice !
If anyone out there has any flying or setup tips for this please pass them along ! What should I use to add weight to the tail ?!?
- John
