RCU Forums - View Single Post - Hangar 9 Twist 3D
Old 06-24-2006 | 05:02 PM
  #4329
Matthew Allen's Avatar
Matthew Allen
Default RE: Hangar 9 Twist 3D
ORIGINAL: Ernie Misner
Jack, your finger is looking MUCH better.... whew!
Mathew, as you probably know, ST says you can lean the midrange by rotating the spraybar a bit -- fuel nipple towards the engne mounting lug. On my G90 I finally put a different brand of carb on it and it cured all. If you have an OS 46 carb, try putting it on your ST engine. (most 40 size engines have the same size opening)
Ernie
I tried rotating the spraybar and as far as I could tell it didn't make a pinch of difference. 'Fraid I don't have another carb either. I could always buy one but it's not worth spending $30 on a free engine when a new one wouldn't be that much more.
I think I'll get it close enough as is for my purposes, and hopefully its behavour will improve with time. Right now it's probably only had about 8 (?) tanks through it.
Oh, btw, thanks Waldo and Ghee-grose![sm=cool.gif]
Matthew
