RE: Tune pipes
No worthwhile info I know of is available .
basically --rpm on these tiny engines is in the 10000 rpm---- minimum -------range . we once did OS61 engines for pattern and the pipe setups were a real pain in the butt.
not only must you get the right length- and volume - you must maintain exhaust systm temperature/pressure to hold reasonable results
a frustrating experience.
