RE: Jamara Swallow-90
majortom
The snapping tendancy of the Yak is not a fault its a traint of the airframe due to the extreme taper of the wing, this is what makes it so airobatic, it will snap if you apply elevator to quickly but if you feed in the elevator in a controled maner you get a true responce, the short moment arm of the Yak will make it change pitch very quickly which stalls the wing and it will snap right every time, so smooth is the answer which is fine unless you are in a panic at the time. Makes for an interesting variation from all those stable Extra's and Cap's HO HO.
MIke
