RCU Forums - View Single Post - specs for current draw on servos
Old 06-27-2006 | 08:13 AM
Krysta
Default RE: specs for current draw on servos
Hi RC-FIEND,
The servo current drain depends on the load but under normal servo operation a servo will draw between 1 and 2 amps when stalled. At idle it will draw about 15 milliamps.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta Hunt
Lead Futaba Customer Service and Programming Technician
Futaba Service Center USA
ORIGINAL: RC-FIEND
Just wanted to know what the current draw specs were for you standard s3003 servos and why this important fact isn't listed anywhere. thanks.
