RCU Forums - View Single Post - Question Re Engine Mounting to Sig 4*60
Old 12-28-2002 | 08:42 PM
Spock
Default Question Re Engine Mounting to Sig 4*60
Dubro makes a 4 stroke throttle linkage just for this problem. It consists of a bellcrank and linkage the will reverse the throw on the throttle. You can also use a 2/56 wire and make a big loop, going forward of the carb and then looping back. The Dubro is a much cleaner solution.
-Rick :thumbup:
