RCU Forums - View Single Post - Question Re Engine Mounting to Sig 4*60
Old 12-29-2002 | 08:22 PM
BlueMax3
Default Problem Solved
Thanks for your helpful suggestions. After fiddling around with the engine mount and using the 4 stroke extension, it looks like it will work as long as I use the first hole on the carb control arm closest to the carb. Hopefully I can make the necessary throw adjustments on the servo end.
Thanks for your help.
Travis
