RCU Forums - View Single Post - Charging Options
Old 06-28-2006 | 06:02 PM
Jackster00
Default Charging Options
I thought for sure there was a dedicated site on RCU for questions about TX'S/RX'S, but cannot seem to find it, therefore, I'll ask it here:
I have a Futaba 7CAP TX, but don't like to use the "wall wart" charger. Is it possible to use a Hitec CG340 field charger to charge the battery thru an appropriate plug in the TX? How about a Hobbyco Accu-cycle (not set to cycle)? I know they have a resistor hooked to the charging jack in the TX. Is this going to interfere with charging? I know I can unplug the battery and charge it separately, but it would be much easier to charge that battery from the TX jack.
I also have a Hitec Flash V. Can I assume that the same advise could be used for that too?
Thanx for any advice.
Also, can I charge a NiMH TX battery thru this TX charging plug?
Jackster
