RCU Forums - View Single Post - tamiya raybrig '03 part question
Old 06-30-2006 | 09:51 AM
Auslide
Banned
Default RE: tamiya raybrig '03 part question
The TEU-101BK ESC which is on most TT-01's will handle down to 23Turn..
I recommed the Tamiya Sports Tuned as Your First Motor Upgrade as in Drift, Speed is Not Essential, Torque and Drift Tyres are..
You can Quite Happily Slide on a Stock Silver can 27Turn all Day..
I have heard Bad things About Fireball Motors So be wary.
I recommend getting Batteries Rated no lower then 2700mah and find a Charger that will Charge Both NiCd and Nimh in a Short Period of time..
a 12 Volt Rapid Charger will do fine , Just Check the Charge Capacity and Times it will take to Charge a 3000mah Nimh
