tamiya raybrig '03 part question
i searched and couldn't find anything on it so..... i'm looking at getting it. i heard someone say to get a metal driveshaft. which one will fit? Can someone give me a pic without the body on it? Also can someone give me a link to which driveshaft will fit? Thank you.
i dont have it yet. thats what it says on towerhobbies. do you know what the stock speed is? i dont expect it to be magnificent. can you give me a link to the right shaft because i see a bunch. i found an item at tower "Tamiya Drive Shaft TT-01" heres what it says it includes.
INCLUDES: Four axles
Two outdrive joints
Two dogbones
so since it includes 2 dogbones and its 4wd does that mean i have to buy 2 of these sets?
Two outdrive joints
Two dogbones
CA
No your looking for a Driveshaft, Center Long shaft.
You should buy it on ebay. Cheaper.
http://cgi.ebay.com/Alloy-Main-Prope...QQcmdZViewItem
Heres what it look like on the chassis
the TT-01 goes pretty slow out the box. Probally 20-24 MPH.
oh. its like 6 something on tower so i'll just get it there. as for an upgraded motor (which i won't do right away, maybe in a few months) i was looking at the fireball 18t. does anyone know the motor limit on the stock esc.
well tower says i should recieve it in about a week!!!!! i got an aluminum driveshaft along with 2 venom batteries. i cant wait to drive it!!!!
Banned
The TEU-101BK ESC which is on most TT-01's will handle down to 23Turn..
I recommed the Tamiya Sports Tuned as Your First Motor Upgrade as in Drift, Speed is Not Essential, Torque and Drift Tyres are..
You can Quite Happily Slide on a Stock Silver can 27Turn all Day..
I have heard Bad things About Fireball Motors So be wary.
I recommend getting Batteries Rated no lower then 2700mah and find a Charger that will Charge Both NiCd and Nimh in a Short Period of time..
a 12 Volt Rapid Charger will do fine , Just Check the Charge Capacity and Times it will take to Charge a 3000mah Nimh
