Help please problem with webra 61
Thanks guys
The carb is the speed carb. It is a new model. The carb I substituted was very similiar, the newer model had a little less metal on the body to save weight however it was essentially the same. I will check the solder joint at the fuel nipple. I will adjust the low end needle for the width you have recommended. Thanks guys for your help. I'm going to the field today to try again. I'll let you know how it goes.
keep flying
Moose Man
