RCU Forums - View Single Post - Dual tail mod experience
Old 06-30-2006 | 08:25 PM
drenalinejunki92
Default RE: Dual tail mod experience
thanks for the great pics. ill probably be copying your set up. my heli one it get into the air takes the name balde a little to seriously... my tail motor just completly drops out and it does uncontrolable 360s. im hopin its not the 4 in 1. A little mod i found.... The tail gear is quite flimsy so after the teether weree completly torn i took the main spur gear from the kyosho mini inferno and used it. even though is a bit smaller it gives higher rpms and more durabilty also the stock black fits perfectly the only problem is fittin the motor to mesh with the gear.. just though id share
