I don't know if anyone thats been in this forum is using theses engines on a lighter plane. You would probably have to get to about 8 or 9 lbs for these engines to hover a plane. The Brillelli 40cc will do the trick.
water.boy,
I like others re-epoxied the engine box and added tri stock where you can get it inside the engine box and added the CapX landing gear. I used all 4-40 control rods and Hitec HS-645MG servos. A little over kill but I had a couple so I got a few more to finish the plane.
ORIGINAL: highfly3D
hello
I would like to see some hover pics from this engine.
highfly3D
