RCU Forums - View Single Post - Dead Stick ?
Thread: Dead Stick ?
Old 07-03-2006 | 08:07 AM
patternrules
Default RE: Dead Stick ?
BW, I'm using the Jeti 90 and on the ground it will cut out if I run it to long, or even a short period at full throttle, the cut occurs after going back to idle, but never have had a problem in the air, I did setup a throttle cut switch just like on the glow motors and set to highest setting, which has always reactivated the throttle.
You may have something else going on sense you hear a POP but that could have been the spinner just coming off.
Setup
C50-14XL
Jeti 90 ESC
TP 5300 2- 5S4P 5300
22X12 or 21X14 apc E
Steve Maxwell
