RE: Possible to convert a servo plug to a motor?
I truly understand your question... the answer is NO
You can not control a motor by simply hooking it up to a reciever...
if somehow you could make a larger circuit board and hook the motor up to that then to the reciever THEN you would be able to use that motor to stear your car
