RE: Need pull pull cable tension help
The easiest way to get the cables at equal tension and everything centered is
to not cut the cables at the servo end. Make one continuous loop from the rudder,
or elevator, control horn through a crimp sleeve at the servo arm, then through
the servo connector, back through the crimp sleeve, then back to the control horn
at the rear. Adjust the tension and center the control surface before you crimp the
sleeve at the servo. Simple and quick.
tommy s
