RCU Forums - View Single Post - ARF DeHavilland Beaver
Old 07-04-2006 | 08:32 AM
swixtt's Avatar
swixtt
Default RE: ARF DeHavilland Beaver
Great... thanks for the beta. I am using the TTPRO .46 and yes it does have a small hole in the end with a set screw. i'll do exactly as you say... that should fix it up perfectly!!
would you suggest running the filter at the point outside the cowl.... that way the fuel line will have a break in it so you can refuel,etc.
thanks again
