RE: FourStar ARF build question
it depend on the aircraft design which way the ailerons go. 99% of the time the wider end goes toward the fuse so your right.
the CA hinges goes in with the skinny side poking into the fuse and aileron. If you have to redo them cut the old hinge and make a new slot next to the old one.
