ORIGINAL: Joe14580
3. Regarding the CA hinges. Which way to they go in ? With the narrow part stuck into the wing or with the wide end stuck into the wing ? There's a slit that is partially cut into the hinge parallel with the "wide" side. The slit is down the middle of the hinge to aid glue absorption I gather. Should that slit be parallel to the wing or doesn't it matter ?
#3 - see this drawing
