RCU Forums - View Single Post - Slipping Turrent
Old 07-05-2006 | 07:32 AM
James S.
Default RE: Slipping Turrent
Don't use zip ties they catch on everything. I found some tape at Autozone that only sticks to itself. Its expensive ~10.00 for 10 ft but it is reusable and you really do not need that much.
I did the glue the clutch and replace the tamiya plugs with deans and still had issues until I cut the right side of the speaker box off (looking from rear of tank) if you do this be sure to put a small piece for metal or plastic to keep the battery from contacting the exposed gears on the right side gearbox.
